jumping spider portraits
I'm experimenting with some new lighting equipment, so I decided to play with photographing the same subject in a couple of different ways.
Just when I was wondering what to photograph, I happened to look down onto the floor near my chair, and was surprised to see what appeared to be a medium sized spider lying on its back. Closer inspection revealed a recently deceased jumping spider. After some ultrasonic cleaning, it looked pretty good except for the cracked carapace that explained its demise.
Anyway, here we have jumping spider two ways.
First, a dark sinister foreboding version with totally misleading eyes that seem to bore right through you...
Crossed-eye stereo:
And then one looking a bit more natural...
A full resolution version of this last stereo can be downloaded from HERE.
Optics were a Componon 50mm f/2.8 set at f/4.0, stacked with a Raynox DCR-150, slightly short-focused to give measured 3.83X magnification. Focus-stepped at .040 mm, 97 and 101 frames, Zerene Stacker synthetic stereo at +-3 degrees. Electronic flash illumination, three flashes through hemispheric diffuser for first image, main and top flash through paper for second image. Canon T1i camera.
Sumguy01
Re: jumping spider portraits
Post by Sumguy01 »
Very nice.
Thanks for sharing =D>
klevin
Post by klevin »
T1i? How interesting....
Interesting photos, though, and a good example of how you don't need the latest/greatest to get good photos, especially under controlled conditions.
Thanks.
Yes, T1i. Sometimes we forget that if these cameras do not fail catastrophically, they generally degrade quite slowly. This particular body has a 15 megapixel APS-C sensor, pixel pitch 4.69 micron pixels, that gives almost the same image quality that it did when new. Using the Nikon rule of sensor pitch = Nyquist limit at diffraction cutoff, this sensor is well matched to effective f/17, and that's consistent with what I found in experimental tests long ago, HERE and in the surrounding thread. So, despite its advancing years, I have no hesitation in using this camera with low mag Mitutoyo objectives (effective f/18 at nominal magnification) or even the f/15 combo used for these images. I also have no doubt that a newer sensor would find some additional detail and have less noise, but those improvements are not high enough on my priority list to have made the cut. I would be much more interested in upgrading my flash units so as to avoid frame-to-frame variation, but so far I've not learned how to do that.
