I assume you mean like the attached image.Chris S. wrote:Ctron,
With a single flash an a polystyrene cup, you have one of the best setups for studio lighting insect that you could ask for. However, you want to do essentially the opposite of what you're doing here: Instead of shining the light through the cup, shine the light into the cup and let it bounce around inside. So use no diffusion at all--just let the light bounce from a wide range of directions--and you should obtain nice, even light. Bounced light can be much easier than diffused light, and can produce better results.
- To do this:
1) Cut a lengthwise portion out of the edge wall of the cup, and shine your flash into it.
....and when the cup is lifted, we see the specimen held by toothpick and clay
With the angle of the flash, I don't think any of it was hitting the specimen directly, but I'm not sure. Do you see anywhere in the image where a flag may need to be placed?2) Importantly, block any portion of the flash from shining on the ant directly. Only light bouncing off the inner surface of the cup should hit the ant. You can use part of the polystyrene you removed to make the light blocking "flag."
Yes, I was able to reduce by a couple of fractions/ stops.3) Since you'll no longer be shining your light through the polystyrene, you'll lose far less of it, so you can probably set your flash for at a lower power, which will improve recharge time and save batteries.[/list]
With careful placement today, I was able to turn the ant upside down and keep it in position.I would normally suggest shining the light from underneath the subject, but your subject support is already taking up that space. So you can put the open portion of the cup, and your flash, above the ant instead. But if you do this, photograph the ant upside down and rotate the final image 180 degrees. As you likely know, our eyes/brains treat the direction the light is coming from as "visual up," since we evolved in a world where the sun was above us. In this lighting arrangement, the side of the ant nearest the flash is actually the least lit, as the flash is blocked in that direction--so visual up is opposite the flash.
ctron wrote:One problem I keep running into is when to stop taking images for the stack. I keep stopping a bit too soon and this makes the extreme end portion of the image blurry. I suppose I might be able to mark start/ stop areas on the course focus knob on the Nikon block(?).
I have a slice of masking tape on the fine focus wheel of my focus block, which helps me count revolutions.
Also, I try to shoot "through" the subject, including some extra shots to front and rear. Most of the time, I throw these away. But sometimes they save me from having to reshoot when I miss on one end or the other.
Further, some members of our community mount an iris as close as possible to the rear of the objective. Then at the ends of the stack, they stop down for a few pictures (which may be more widely spaced). The stopped down images have greater depth of field, though less resolution, and can provide a more pleasing transition from in-focus to out-of-focus elements.
If you're using the live-view histogram, don't trust it overmuch, as in my experience they aren't all that accurate. If you're shooting an image and then checking the histogram, this can be much more accurate. Make sure you are using an RCG histogram, and not single-channel or luminosity histogram. Also, at magnifications like these, small highlights go in and out of focus shot by shot. When such a highlight is out of focus, the bright bits are averaged with less-bright bits, so OOF highlights appear darker than they will be when in focus. I make it a point to set my exposure with an in-focus frame, and test it on a few frames with different points of focus.ctron wrote:I can't really go by the back of the camera histogram for stacking. If I try to keep highlights where they should be, the final stack is too dark. Seems like I have to almost clip the highlights, but the stack doesn't turn out overexposed. Not sure what's going on there.
Not sure if any of the above answered your questions?
Cheers,
--Chris
I think it did help, yes, but I'm still running into difficulties. I did replace the cup I was using with the one above and inverted the ant, but I then was ending up with a very bright ant bottom and too dark of a topside. I also had to use Lightroom to reduce exposure by 2 stops as especially the bottom of the ant was way overexposed. If I try and adjust flash so that nothing is blown out, I notice that Zerene has the tendency to produce a final stack darker than the individual frames, which may have looked quite good during acquisition. I then have to try and increase the brightness of the darker result.
The flash lighting difficulties are still the main thing holding me back. I just can't seem to get uniformity, either too bright or too dim. If I get one part of a specimen just right, then the other part is blown out. I'm not using the camera instant histogram either.... I go back after the image is taken and view it. If it's where it should be the final stack ends up too dark.
I notice that some people make sub-stacks to be later combined to produce a composite. I'm not exactly sure of the reason. One could be that I notice Zerene has the tendency to change areas already stacked sometimes where maybe there would have been a better stack of just a particular area earlier on. It could also be for exposure reasons too. As I said, I reduced by 2 stops all frames in Lightroom and then stacked. I have another stack where nothing was changed, and I could probably reduce by 1 stop for another stack. Sort of like making an HDR except software changing exposure and not actually taking new images. I just hoped I could avoid the extra work of these methods.
I'm also not sure if an objective is suited to specimens filling only half frame. I don't see many ant whole bodies taken with objectives, usually only the heads. Rik kindly pointed out the odd positions dead ant bodies would be in and I agree, but maybe there's some flaring going on too with objects not filling the frame. I know I've pretty much tried everything and still ending up with speculars and or washed out detail areas.
Just some thoughts....
