I have a Nikon PB-4 coming in from eBay. Super pumped!
It has Nikon to 39mm (female) adapter.
BUT
I'd like to reverse mount an enlarging lens with a 30.5(?) female front thread.
I -think- I need a male to male 39mm to 30.5 adapter.
Can any of you give me a tip toward finding who makes one of these?
Thanks!
Source for male-to-male adapter?
Re: Source for male-to-male adapter?
A 3d printer is your next friend
Ha~!
Given my tendency to have obsessions when other people have interests, I'd like to avoid that particular rabbit hole...
f
f
It is unlikely you will find that, but you can find step-up and step-down rings that link the unusual threads to a common size, and then you can use standard male-male rings.
I would do as Lou suggests, and I look first for 52 mm as the intermediate because so many things come with that.
At this moment I find on eBay:
https://www.ebay.com/itm/162089376565 39-52 step up (39 male, 52 female)
https://www.ebay.com/itm/151841869583 52-52 male-male
https://www.ebay.com/itm/223435686657 30.5-52 step up (30.5 male, 52 female)
Also note that Nikon makes a BR-2 reversing ring that fits the F-mount. and that gives you additional options.
I too would go for the solution suggested, but I think there also are more expensive options:
customphototools.com/enlarger-lens-reverse-adapters/
(I have no affiliation whatsoever. Made to order?)
My contact in China makes such rings for around $20 (simple ones), if you are desperate. He will need the thread pitch and some other parameters such as thickness.
Adding in outbound shipping, the $20 quickly becomes $40-$50.
My suggestion is to get a more standard thread for your bellows and purchase/order rings to that instead of having a specific ring for each lens.
get a reverse mount ring Nikon -> filter thread like this for 52mm
https://www.aliexpress.com/item/1005003 ... CWgUi6xvsY
and then a step down: 52->30,5
I find most of these aftermarket Nikon reversing rings to be either too loose or too tight. I highly recommend the ring I mentioned above instead, the original Nikon BR-2 ring (or BR-2A, which for this application is identical to the BR-2).lothman wrote: ↑Wed Jun 07, 2023 1:47 amget a reverse mount ring Nikon -> filter thread like this for 52mm
