Test results for the LFOV have been posted on my site:
https://www.closeuphotography.com/scitex-lfov-lens
These is the lineup for the test at 1.1x. The LFOV is a big lens! This copy came from a Scitex Eversmart flatbed scanner.
Crop areas highlighted on the full un-cropped disk image
These are the center crops at 1.1x, you can also see edge and far corners crops on the full test on my site.
LFOV vs Componon-S 5.6/100. CPN mounted in reverse, LFOV normal mount. The CPN is optimized for 0.5x. LFOV is optimized for 0.6-1.5x.
LFOV vs Scitex S-3 110. S-3 was measured at f/5.2, LFOV, f/5.8. Both lenses mounted normally. Both lenses optimized for the same range.
LFOV vs Makro Symmar 5.6/80. Both lenses mounted normally. MS80 optimized for 1x. Super results from both lenses.
This is the setup of the lens in the Scitex Eversmart flatbed scanner.
Test Notes:
The LFOV is not easy to find. I bought one used and for a second copy I was lucky to find an Scitex Eversmart Scanner in California for $200 (with a free mac
2 other lenses were tested but left out of the results since they were too far out of their designed range at 1.1x, the Linos Inspec. x L 5.6/105 3.33x model and Fuji EFC 5.6/108 lens. The linos had fantastic results in the center but the corners fell off quickly.
Test Setup:
Camera: Sony α6300, model # ILCE-6300, also known as: A6300
Sensor size: APS-C. 23.5 × 15.6 mm. 28.21 mm diagonal. 3.92 micron sensor pitch
For this test a stack of images was made with 10µ (10 micron) steps and the sharpest frame was then chosen using Photoshop at 100% actual pixel view. Separate images were selected for each crop area. Each image was processed in PS CC with identical settings with all noise reduction and lens correction turned off, all settings were zeroed out (true zero) and the same settings were used for all of the images. All of the images shown here are single files.
Final Thoughts:
The LFOV lens is highly recommended, if you can only find one!
Questions comments always welcome.
