Quick question. What does the slot screw B do ? The Zeiss Fluoro condenser manual only mentions slot screw A, which focuses the iris. There seems to be a heat absorption filter around there, but it doesn't make sense to focus that, does it?
No, you don't want to remove the diaphragm but to open the tube by the other side removing the three bolts around it, one of them marked with a blue arrow:viktor j nilsson wrote:So, to remove the heat-absorption filter I need to loosen both slot screws (A and B in the first picture), unscrew the iris screw (3.8 in the manual) and both centering screws (3.5). Then I just slide out the iris assembly? Is there anything that can come loose in the process that I need to be aware of? Is the spring-loaded pin tricky to get back in place?
Yes, I have two lenses and with most LEDs I have the HBO lamp house lens is much better, the Halogen* 100 lamphouse lens oly works decently with the big Cree XML2 . The HBO lens has much shorter focal length than the Hal.I believe you tried both the HBO50 and HBO100 lamphouses - did the filament magnification change significatnly between these? I am going to try out a couple of different options to see if they produce a sufficiently large illuminated field. The LED dies also varies quite a bit in size, so I don't think that there is going to be a single collector lens that is ideal for all of them.
It's surprising, the more prone to be fried are typically the EX filters, and for a good reason! so I think that someone changed it.viktor j nilsson wrote:In the other cube (FITC?), the purple dichroic mirror and the green-yellow barrier filter was fried. The excitation filter side, however, looked OK. This side contained two identical stacked filters. They weren't labeled and looked like this:
They look a little too dark-blue to be a 470-500nm filter, don't you think? Does anyone have an educated guess as to what they are?
Thanks for confirming this! Based on their looks, I guess that they are quite similar to the B46 filter I have, but maybe shifted a little deeper into blue-violet. Could be a useful barrier filter for longish UV to blue.Pau wrote:It's surprising, the more prone to be fried are typically the EX filters, and for a good reason! so I think that someone changed it.viktor j nilsson wrote:In the other cube (FITC?), the purple dichroic mirror and the green-yellow barrier filter was fried. The excitation filter side, however, looked OK. This side contained two identical stacked filters. They weren't labeled and looked like this:
Yes, they look too blue, my Chroma HQ480/40 FITC exciter looks greenish
