Bizarre Nikon Optiphot photo tube attachment ID request
Recently I bought an Optiphot microscope (I think it is model 66) with “T” trinocular head that has a bizarre attachment (I tried to search the web for picture/description with no luck at all) so I will appreciate if somebody will be able to identify this beast. I am attaching a few photos as this will serve the purpose better than me trying to describe it.
Thank you in advance
mbb, welcome to the forum!
It looks like you're getting a handle on the image upload procedure.
If you need them, instructions can be found at https://www.photomacrography.net/forum/ ... ic.php?t=7 , in the Image Hosting Procedures forum.
Thanks, Rikrjlittlefield wrote:mbb, welcome to the forum!
Seems that I figured it out; could you please remove double in the second post - this I still need to learn
The part (A) in pictures 7-9 is the Nikon "chimney". https://www.photomacrography.net/forum/ ... p?p=206784
The lens at the base is a tube lens which takes the image from infinity and produces an intermediate image (normally for a projective).
The chimney looks unusual in itself; I suppose that the top part has been removed to reveal the interior that you wouldn't normally see.
The adapter (B) in pictures 3-4 looks custom-made. Very unusual. Can you say something about the optic (? eyepiece) inside adapter B?
Regards, Ichty
Regards, Ichty
Hi, IchtyIchthyophthirius wrote:Hi,
Regards, Ichty
OK, A) I did not label “chimney” - } indicate that this tube with lens mounted on it is inserted deep into the chimney. I also found this chimney to be strange in this model. BTW black tube sticking out from it seems to be permanently attached
Thanks, Mark
You wouldn't see the polarizing effect in the eyepieces and that, to me, makes it an odd place for a polarizer.ChrisR wrote:B would be for a polariser (analyser), surely, but it looks like it may be off something else!
mbb, does anything within the barrel move up and down when the lever is rotated?
-Gene
Hi Gene;genera wrote:You wouldn't see the polarizing effect in the eyepieces and that, to me, makes it an odd place for a polarizer.ChrisR wrote:B would be for a polariser (analyser), surely, but it looks like it may be off something else!
Part B is constructed with three barrels. The inner one has a small lens (~8mm) at the bottom - lever rotates this barrel (90-degree movement and is locking on both ends, small grooves at both ends) so the lens can be rotated in the horizontal plane only (no parts are moving vertically at all in the whole setup). The outer barrel is housing and is providing restriction points. Barrel in the middle also can rotate 0-90 degree after untightening the knob and is providing smooth movement – can be locked at any point by tightening the knob, but if you tighten little screws in lower part of middle barrel it will lock it to the top part of the tube (part A) inserted into the chimney and there is no more movement possible, knob tightened or not. BTW you can see marks left by tightening these screws in different places around the top part of tube A; and when part B was turned with partially tightened screws. I can only think that this process serves the only purpose of adjusting the position of part B.
Mark
