V-Slot Extrusion.. some 3D prints to make some parts play well.. mainly the tube clamps.. I want the tube axis perfectly aligned with the tip of the insect pins I use.. My stage only allows 1cm adjustment in the vertical, and the easiest way was to design clamps with the exact height in the base.
Not sure if it is a good idea to have the flashes mounted in the frame (vibrations).. it's practical but... (anyway I use led panels most of the time)
No wires around (but the power cable for the controller) .. everything is inside the frame.
Small .. only fills a square base of 45 cm (18"")
A fisrt test only to check if everything was running fine.. just used one Jansjo lamp.
I also did it compact to fit inside a small dome .. I would like to try stacking outside in the patio with natural / sunlight rather than artificial light.. I'm not sure if it works, and I fear the heat generated inside the dome will make subjects to move during the shooting...
The parts for the dome did not arrive yet...
António
