agreed, the F-stop T-stop difference could introduce some errors when trying to calculate the physical aperture - but since I don't see a way to do it without a reference lens there's not much we can do about it, and on most modern coated lenses the light loss is fairly consistent.ray_parkhurst wrote:I would worry about not using the same lens for the tests. I've seen fairly significant differences in exposure between lenses of same aperture. T-stops?
I don't see how you could do it with the same lens - I thought we were talking about stacked lenses of unknown aperture here and the idea is to use another lens with known aperture for exposure comparison and calculate the F-stop (or more precise T-stop) of the unknown lens based on the exposure difference?Anyway, using same lens would fix that, but then I'd need to rely heavily on the curve. I'm not sure how to linearize the demosaicing/raw conversion.
an easy way to linearize the RAW data values seems to be maketiff (I only used it briefly because my workflow usually involves Lightroom):
https://www.colorperfect.com/MakeTiff/
