Raynox on Harley
Online
Adalbert
Raynox on Harley
Post by Adalbert »
Hello everybody,
This time I would like to present you the Raynox DCR-150 mounted with Harley clamps:
- distance between Raynox and microscope lens = 5,5cm
- distance between Raynox and camera sensor = 20cm (till 17cm)
BTW, SIGMA LSA on Harley looks like follows:
BR, ADi
lothman
Post by lothman »
Thanks for pointing me to those Harley clamps. I will order some of those. Does the flat face need some machining where they contact the arca clamp? They look like cast material without machining so they might wobble a little.
regards
Lothar
P.S. for tubes with smooth outer surface you could go for T2 Extension tubes and, convert them with a M42x1 -> M42x0.75 or use a T2-Adapter directly for camera connection.
Link to ebay auction for T2 extension tubes
Online
Adalbert
Post by Adalbert »
Hello Lothar,
Hmm, probably it would be better to adapt the Harley to Arca but I haven’t changed anything.
BTW, the diameter of the delivered screws is 7,8mm but I have mounted the Harley to the Arca with the UNC ¼”
BR, ADi
