Olympus U-TR30 vs U-SWTR Full Frame Coverage
Does any one know if projection at photo port on U-SWTR will cover full frame sensor? I am using U-TR30 at the moment and unfortunately it does not. Thank You.
I am using an U-TR30 with full frame sensor and the sensor picks up the "square" inside the circular field of view. So yes, the field of view if fully covering the sensor. I think Waldo Nell is using a U-SWETR and then get vignetting instead.
What photo eyepiece are you using? You should use a PE2.5X when projecting onto a full frame sensor.
https://www.instagram.com/micromundusphotography
https://www.flickr.com/photos/micromundus
https://www.youtube.com/channel/UC0UdYN ... YH_litDZjA
Olympus BX51 | Olympus CX23 | Olympus SZ4045 | Zeiss EVO LS 10
I guess then you need to use a smaller sensor size. However, then you are loosing other advantages like higher dynamic range etc that you get with a full frame sensor. I explored different options a couple of years ago and tested both small sensors and bigger and decided that the best compromise for me was to go for full frame and a photo eyepiece.adamski wrote:Hi, yes I know that with PE 2.5 you will get coverage of full frame but I don't want to use any optics just direct projection straight onto camera's sensor.
Are you afraid of additional aberration and reflections or why do you dislike a photo eyepiece in between?
A wide field head will help, but not enough for illuminating a full frame sensor. I believe Charles is using a smaller sensor which helps in this case.
