Choice of color temperature for the power LED flash module.
fotoopa
Post by fotoopa »
I'm going to update my old LED flash for higher power. The old module has 12 Cree LEDs type 9V 400mA. There are 6 channels used for controlling.
Led flash module, leds + PCB PB102673 by Frans, on Flickr
Snout added on my ledflash module PC082720 by Frans, on Flickr
I would like to use the old housing. Only the ring for the LEDs must be remade. Given the LEDs are larger, there is only room for 10 new LEDs. The shape is the CXA 1830:
High power led flash module by Frans, on Flickr
These LEDs are available in different color temperatures. The CRI value is greater than 90, the 3000K version exist with a CRI between 93 and 95. The higher the color temperature the more lumens give the leds. I doubt between 5000K, 4000K and 3000K LEDs. 3000K is slightly more expensive but this does not matter to me.
The types are:
CXA1830-0000-000N0US450F 5000 K 2990 lm
CXA1830-0000-000N0US240F 4000 K 2780 lm
CXA1830-0000-000N0YQ430H 3000 K 2260 lm
links:
http://www.mouser.be/ProductDetail/Cree ... 6ChCmHkDhZ
http://www.mouser.be/ProductDetail/Cree ... Qd0A%3d%3d
http://www.mouser.be/ProductDetail/Cree ... uQbg%3d%3d
This leds are nominal 800 mA and max 1400 ma. I would use them at 1200 mA. The light output is than 140%.
Total power for 10 leds @ 1200 mA:
5000 K version 41860 lm CRI90 power ratio 6.16 x --> 12.51 euro (min 10 pieces)
4000 K version 37800 lm CRI90 power ratio 5.56 x --> 12.51 euro
3000 K version 31640 lm CRI93 power ratio 4.65 x --> 13.97 euro
My current led module has 6800 lm max ( 12 leds 355 lm x 1.6 @ 720 mA). The flash time is now 2.4 msec on the gray card with the Mit 2X, 5X and 10X lenses. I would use 10 channels to control the LEDs. The LEDs are driven at constant current of 1200 mA or 12A total @ 39V. I have 4 x 10.000 uF capacitors. With a voltage of 52V all LEDs can flash up to 40 msec ( tested ). Design is finished, pcb layout is ready for etching. I am still waiting to buy the best LED type.
Update:
A few extra pictures:
PCB board design:
led 10channels components. by Frans, on Flickr
Layout pcb:
led 10channels pcb by Frans, on Flickr
Shema:
led 10channels shema by Frans, on Flickr
Test with picoscoop:
powerleds_1000uF_40msec_3A by Frans, on Flickr
Setup of the test:
Test for new power led module P6246027 by Frans, on Flickr
For higher resolution picture see the Flickr links.
Frans.
mjkzz
Post by mjkzz »
I personally have never had any successfully custom white balance, particularly with my crapy Canon 550D that does not allow color temperature to be entered directly.
But if one shoots in RAW, color temp probably would not matter.
fotoopa
Post by fotoopa »
To set the white balance, I have no problem with the D7100. Through the tethering software I can define the white balance and store it in the D7100 preset values. With a gray card this appears quite correct. My current power LEDs have a color temperature of 5000K and a CRI of 90. I shoot always in RAW. Now I read that a high CRI is not everything. A good CRI give no guarantee for perfect color yet.
I would now rather decide to purchase the 4000 K version with CRI min 90. Is slightly cheaper than the 3000K and gives something more lumens. I think there's hardly anyone here on the forum has made a practical compare. In order to purchase both types and comparing it seems to me that too expensive. Tomorrow or at the latest Monday morning I do the ordering of the power LEDs. The LEDs I do not solder, you never know if I can replace them later with other versions (same shape).
mjkzz
Post by mjkzz »
cool, I know it is me who can not do custom WB right :-) So when it comes doing custom WB, I just change to RAW. As matter of fact, I think I am going to shoot in RAW -- my studio strobes do not seem to give me the same color temp as speed lights, like Canon 580EXII or YN560
Can't wait to see your results.
fotoopa
Post by fotoopa »
mjkzz wrote:Can't wait to see your results.
There is quite some work. The unit comes in my darkroom space this is 5 meters from the main controller. A SPI protocol line will send data and commands to the flash unit CPLD:
But I'm working on it.
Frans.
mjkzz
Post by mjkzz »
wow, 5m long SPI bus.
I like 485 bus and you can always replace/interface with it with wireless module available off the shelf, reliable and cheap.
fotoopa
Post by fotoopa »
No problem, I use twisted pair cable with terminating resistors and never wireless. I've never had any problems with signals up to 1 MHz clock. I would take RS485 for industrial use because this is indeed better. Another solution is with 50 ohm drivers. Start signal for the flash is via a separate direct connection.
Post by Chris S. »
Frans,
Thanks, as always, for your fascinating post. I wait to read them until I have time to do so slowly and carefully. This is always worth it.
fotoopa wrote:I would now rather decide to purchase the 4000 K version with CRI min 90. Is slightly cheaper than the 3000K and gives something more lumens. I think there's hardly anyone here on the forum has made a practical compare.
I think you’re right that no one here has made a serious comparison toward determining optimal color temperature for macro photography. I’ve done a very little bit of this, and suspect that optimal color temperature is subject dependent.
In the macro studio, I shoot with Halogen illuminators and fiber optic light guides. My illuminators have EKE bulbs with a color temperature at full voltage of 3200K. But I usually shoot with them at 80 percent of full voltage, which greatly lengthens the bulb’s life span, and lowers color temperature to 2500 Kelvin.
With a subject that contains bright red-channel information and dim blue-channel information (a not-uncommon situation), I often get more noise than I want in the blue channel. In such a case, if I turn my illuminators’ dimmer switches up to full voltage, the higher-color-temperature light (which of course increases the proportion of blue light to red light), I get a less-noisy blue channel, and a resultantly better picture. So my sense is that for subjects with a lot of contrast between the color channels, it might be useful to have a range of color temperatures of light available. And of course, one could probably do much the same by placing a color filter over the light, then backing out its effect using the color channels in Photoshop. This is something I haven’t gotten around to trying, yet. But since in my experience, a noisy blue color channel is a more frequent occurrence than a noisy red or green channel, I’d lean toward the highest color temperature LEDs, which contain the most blue light.
The 5000 K 2990 lumen Cree LEDs you reference are quite interesting to me. These seem bright enough that I might consider modifying my Halogen illuminators to switch out the EKE bulbs for Cree LEDs. This would probably let me run the exhaust fan much more slowly, and switch from solenoid shutters to electronic gating.
mjkzz wrote:I personally have never had any successfully custom white balance, particularly with my crappy Canon 550D that does not allow color temperature to be entered directly.
fotoopa wrote:To set the white balance, I have no problem with the D7100. Through the tethering software I can define the white balance and store it in the D7100 preset values. With a gray card this appears quite correct.
mjkzz wrote:cool, I know it is me who cannot do custom WB right :-)
Mjkzz: I, like Frans, also use a Nikon D7100 for studio macro, and find it easy to set custom white balance. I’ve found it even easier with my other Nikon bodies. I don’t bother with automated custom WB. I simply take pictures of a white card and look at the three-channel histogram of the results. I adjust the color temperature in camera or in tethering software, until the red, green, and blue histograms' peaks are right on top of one another. This is quick, simple, and has always worked.
mjkzz wrote:But if one shoots in RAW, color temp probably would not matter.
Agreed that color temp won’t matter inasmuch as it can be adjusted in raw conversion. But would suggest that color temp of light (not camera settings) may matter in terms of getting lowest-noise images.
Cheers,
fotoopa
Post by fotoopa »
Thanks Chris for the comprehensive and detailed explanation. I now think even more about the choice of the color temperature of the LEDs. Especially considering my current LEDs used have also 5000K. At that time ( Sep 2014) the price was quite high and the power a lot smaller. Now you have much more power for the same price and more types.
I've just taken an overview of the Cree specs:
Regrettable there are only diagrams with a CRI of 70 at the high temperature versions. But you can see clearly increase to the blue. The LEDs I'm going to order a bit later and first finish the PCB's. The SPI connection I'm going to replace possibly. Then I would not need the local CPLD and the control would occur directly from the current existing controller via a cable with 10 twisted pair wires over a distance of 5m. I will first have to test those signals with scope and logic analyzer. Only the high power section of the control would be in the darkroom. Within a few weeks I can decide if I take the 5000K or 4000K LED version.
I post the measurements later on.
fotoopa
Post by fotoopa »
mjkzz wrote:wow, 5m long SPI bus. I like 485 bus .....
You're right, that's a better solution. In my old stock, I found the RS422 driver - receivers type MC3487 and MC3486. So with 3 pieces each, I have to 12 differential RS422 lines. Thus, the outputs of my FPGA lines shall have a nice buffer to the outside and the speed is very good. The CPLD chip is no longer needed in the darkroom space. This saves me the verilog code for the SPI driver. All programming remains on the stack controller side box.
Thanks for the usefull idea!
Thanks for posting the spectra graph, this is was I was referring to in the PM. Despite the higher 3000K CRI I find that the main difference is blue mitigation (not always desirable and a bigger amount of red towards the far end but the main issue with LEDs still remains: the valley in the cyan - green zone. I don't see the increased amount of far red of much utility, I think that the 4000K spectrum is more equilibrated in green-yellow wavelengths, but my opinion is more speculative than based on experience.
mjkzz
Post by mjkzz »
Thanks Chris.S, I think I just never sat down and try to do custom WB with all of my attention. I did a smaller ring and a panel flash with 90+ CRI and color temperature of 2700K-3200K LEDs, tried to do custom WB, but eventually I simply went to RAW and adjusted pix in Light Room. But I do agree with you, maybe 2700K - 3200K is too warm and need a little more blue.
Frans, that sounds great, glad you got some ICs in your stock drawer :-) I am looking forward seeing your results, always amazed by your pix over Flickr.
fotoopa
Post by fotoopa »
Pau wrote:The main issue with LEDs still remains: the valley in the cyan - green zone.
I was looking to add a second ring SMD green leds, 10 pieces in series as one channel, mechanically it would go. But I do not see how to solder them. There are green LEDs having about 180 lumen/piece @3.65V and a size of less than 4mm. So 10 leds give arround 1500-2000 lumen extra into this zone which is very expensive and complex in order to achieve. First I will make adjustments to my PCB for the rs422 receivers, so there's more time to make the choice for the right LED temperature.
mjkzz wrote:Frans, that sounds great, glad you got some ICs in your stock drawer :-)
I think there are about 1000 pieces of various kinds from the years 1980-2000. Especially TTL, ALS, S, HC and HCT versions and just about anything for Motorola CPU's and peripheral chips, memory and EPROM's. Most of it is outdated but occasionally still usable.
fotoopa
Post by fotoopa »
I have decided my choice type led temperature. It will be five pieces at 5000K and 5 pieces at 3000 K. They will be alternately mounted. Thus I have the choice of a group of 3000K, 5000 K and a mix of both. I will make into the camera 3 presets for white balance. This way I can judge the impact of the color temperature of the LEDs. Consequently, there will be 5 or 10 LEDs used at a time. I've tested this with the existing version with 6 channels. The brightness distribution remains perfectly maintained with only 3 leds, only the time needed is the double. With five channels it will be even better distributed. I see that the price of 3000K version in the meantime is pretty dropped.
The versions are:
CXA1830-0000-000N0US450F CRI 90 2990lm 5000 K
and the
CXA1830-0000-000N0YQ430H CRI 93 2260lm 3000 K
Meanwhile, all new PCBs are designed and ready to etch. The technical drawings are also ready for the 10 LED holder. The list of components is now being prepared and will be ordered this week.
The following is still a lot of work, especially 3 to 4 weeks. Grandchildren also come a week vacation, I can not work during that week. As soon as parts are finished, the photos will be online.
Post by Chris S. »
Frans,
Sounds like an excellent choice--elegant, and potentially a nice step forward that the rest of us can copy. I enthusiastically look forward to your reports.
Cheers,
--Chris
