Good looking scope, congrats!
In these models almost all is centerable...so it's also decenterable
. Be patient with centering, don't touch what is working well: it's easy to go wrongly, I have experience!
Aside of the obvious, the condenser, you can also center
- the auxiliary sub condenser lens: it has two or three small screws
- the dovetail mounts with the bolts at female dovetail holders (removing the screws that hide and lock the actual bolts that hold the dovetail in place).
- the mirror/field diaphragm assembly also can be regulated a bit losing the fixation screws and playing about 1 mm with its position
- even the arm to base fixation playing with by the same system
The auxiliary lens is in principle intended to get more even illumination with low power objectives. With your 0.9NA condenser it isn't that necessary but can improve illumination in some cases. I use it most the time with my DIC hybrid setup because it allows to put the condenser at different height.
I have not a good method to center the microscope, so I'm interested to know if there is one too.
The simplest and more important centering operation is with the condenser. Often you need to center it for each objective but the usual approach is to begin with low power focusing the field diaphram with the condenser at the slide plane (standard method for Köhler) and improve it for each magnification step. If when you go downwards it remains approximately centered, your scope is likely to be well centered.
If when putting the subcondenser lens the field diaphram image decenters, try to center that lens
