No need to sell your Axiostar if it works well: it's a very nice scope. To get DF you can buy DF stops from other sellers, even the original zeiss one does appear on ebay although not very often. You can also couple a dedicated DF condenser that is much nicer for high magnification.
Please measure the condenser mounting dovetail diameter and the condenser height and let me know: if it is the same than the one for Standard series, that condensers sells often, sometimes at reasonable prices
You can easily make darkfield sliders. I make DF stops each year with my students: it's easy and works well for up to 20X: just make a plastic slider of the adequate dimension and glue a black disc. You can use the "unkind seller" stops as model just measuring your slot opening and scaling the dimensions
