In the meantime anyone have the service manual for this. As in how to take it apart and lubricate, and what to lubricate it with etc ...
Someone suggested it might be a Zeiss Standard RA
This is the only Logo/writing on it
4 position. Fixed is the nosepiece type I imagine. It looks as if it is replaceable.Yes, it looks like a Standard RA (about 1960s), the variant with a fixed 4- or 5-position nosepiece.
Good point.As for servicing/lumbricating, only do this if absolutely necessary. It's easy to damage, break or mis-align components ...
Did not know I had to. Why is that? Is it to align the mirror at right-angle to the light source?...(for example, did you mark the position of the Diaphragm insert before you took it out?)
- Yes, The nosepiece and its nosepiece holder (the microscope head) is replaceable, I did it recently to convert my Standard 16 to Standard 18, ie with a dovetail changeable nosepiece, but I don't recommend doing it yourself: to mount it at the right position mantaining both paralelism and centering was really painful, after a whole afternoon mounting and testing I finally got it right just when I was close to abandon, clearly something to be done at the factory with dedicated tools, not at home.(*)75RR wrote: 4 position. Fixed is the nosepiece type I imagine. It looks as if it is replaceable.Did not know I had to. Why is that? Is it to align the mirror at right-angle to the light source?...(for example, did you mark the position of the Diaphragm insert before you took it out?)
Hi Glen,75RR wrote:4 position. Fixed is the nosepiece type I imagine. It looks as if it is replaceable.
It's prudent to always mark the original positions before you remove parts, in case they had been pre-aligned by the factory. In your case it doesn't matter any more, since somebody had already removed the insert before, so what ever alignment there used to be, it's gone.75RR wrote:Why is that? Is it to align the mirror at right-angle to the light source?
Hi Ichthy,Ichthyophthirius wrote:Yes. That's provided by screw 1 (M5; 4-stared grip)75RR wrote:Does one need (forward/backward) movement in order to focus with a led light?
There are a lot of LED replacement ideas and LED power supplies on the internet. It's a project rather than a quick fix.
All the replacement requires in terms of Koehler illumination is placing the LED in exactly the same position as the original lamp filament, and having a single-chip LED with a sufficiently large chip. Maybe someone in the forum with experience can make a recommendation?
As for the aluminium rod, here is one suggestion (no guarantees):
Take an aluminium rod, 20 mm diameter, 120 mm long.
Get a workshop to cut an M19 thread around the outside of the bottom 50 mm of the 120 mm rod. The bottom of the rod will now fit through the hole in the lamp socket (20 mm diameter).
Use two M19 counter nuts (either side of the lamp socket) to fix the rod in the illuminator. The thread is 50 mm long, so you'll have room to find the right position.
Get a single-chip LED on a star platine, solder on wires, and glue the LED to the flat top of the aluminium rod using thermal conduction glue.
Connect the wires to a suitable power source.
Scetch (not drawn to scale)
[ anybody got an idea for a suitable LED dimmer? ]
Got this reply: "It does not have a part number but it will fit the Zeiss standard 14 to 18 and the WL size"Getting a "new one" sounds easy, but there were two common versions (there were in fact even more), 46 70 57 (for Phomi III and Universal) and 46 70 58 (that's the one you want; for Standard) which differ in their collector lenses (again the reason is the difference in the size of the bases of the different models) but the number is rarely written on the Diaphragm insert unit. So you either have to ask the seller where the Diaphragm insert came from, or feel lucky, or transplant the iris into your old insert.
This one is to mount a 10W 6V halogen lamp, not to use with your 60 lamp house.g4lab wrote:http://www.ebay.com/itm/231373408190?ss ... 1555.l2649
I have this similar item up for auction at this time. It is later than the one pictured above and consequently has more plastic. It does have a plastic slide that a lamp holder can be mounted to and slide back and forth to focus the lamp. I don't have the lamp holder. Zeiss new spare part. old stock.
