Basic system: Nikon D800E + Nikon's excellent (no longer available new) Micro Nikkor Zoom 70-180mm lens (beat's the pants off my old version 70-200 VR lens for sharpness, all I have to compare to) as a tube lens, + microscope objective. I have reordered the M25 adapter from jinfinance/eBay (misplaced my other one).
Re objectives. I now want to try out two Leitz objectives I have on an old Leitz Ortholux. I didn't find the thread size (googled), but
IS IT RMS?
I eyeballed the objective threads against a plastic ruler... ~ 20mm
I have A) Leitz Wetzler Plano 2.5/0.07 C 22423 made for a 170mm focal length, so think it would work with my 70-180mm zoom lens.
B) Leitz Wetzler Plano 4/0.10 C 14588 also 170mm focal length...
Before I lost the M25 adapter, I had tried with excitement the Nikon 4X objective (700 stack using StackShot).
I am a noob, so would like any opinions on which 4X (that I own) is the better quality... the Leitz 4X I own or
Nikon E Plan 4X/0.10 MRP70040 that I own?
If the Leitz objectives are RMS, then I will order adapters from jinfinance/eBay. If they are not RMS, is there an adapter I can use?
(to connect to a 52mm lens, will also use step rings to the 67mm filter size 70-180 Nikkor)
Regarding RMS filter adapter, should I get both the cone and flat adapter since I have other Nikon lenses to experiment with? Best one for the 70-180mm lens?
Re Nikon 1V1 Has Anyone used it with stacking with a Microscope objective/bellows/or reversed lens setup (I have some Nikon 1 lenses as well as FX and DX lenses?
I already had the camera, which I bought a few years ago to use with regular Nikon lens via the WT-1 adapter... super magnification
Celestron's 2MP digital imager which I just place in Celestron's Stereo-microscope (Model 44206) eyepiece tube. I was unhappy with the horizontal brown bands I see when an imager is placed in the eyepiece tube (happened with the Nikon 1V1 using C-mount adapter also). Trying to work that out (tried make shift LED lighting (for microscope slide) versus their horseshoe shaped fluorescent tube, better but...
But got to thinking Nikon 1 V1 could be advantageous since it is mirrorless and has an electronic shutter option, thus reduced vibrations with stacking photos.
Also thinking (crudely, I'm not an engineer or optics person) the CX sensor (2.7x) could be interesting to try out.
For the V1, I'm on the verge of ordering an Eye-fi card Pro X2 so I can see the images on my computer without removing the SD card from the camera, plus Nikon 1V1 has no tethering options and is not supported by CamRanger. Eye-fi will make it easier to pick the Start/End positions on the StackShot. I can trigger the shot via an IR device and use StackShot in Manual Mode (there may be other ways to use StackShot I have not investigated yet with the V1 camera)
edited to add Left field question: I would like to photograph corn pollen on a corn silk (can bring indoors for studio setup). How long will the pollen last, thinking I may not receive my microscope objective adapters from China before pollination season is over. I have never shot pollen before, so not sure how it deteriorates or can be kept (I know the silk will turn quickly!).
I realize this is a 'scatterbrained' disjointed post, but I will appreciate any responses to any part of it. In a nutshell, I am trying to use equipment I already own to make better photos, both of microscope slides and of no-slide objects. So much knowledge and helpful folks here, thanks.
