It's my first time here.
I started macro not long ago, when I saw I could reverse my 50mm to make amazing pictures, I added a bit of equipement later on and now I need some advice.
I am currently able to get 2:1 ratio with my 50mm and extension, and 3:1 with a 180mm and a reversed 58mm at the end.
However, I was interested in buying a 28mm to get 2x and 4x with tube (those are my aprox calculations, based on the ratios I get with all of my lenses)
I was considering normal 28mm lenses in any mount before I came by here, and I was recomended the olympus zuiko, canon fd and nikon als for low cost lenses.
I now see there is also enlarger lenses, telescope lenses and much more techniques that could help me get that ratio, but the most important thing for me is that I want to be able to still take pictures handheld WITHOUT stacking, so from what I heard microscope lenses might not be ideal for that.
I am looking for cheap used gear (maybe 50$?) if that's possible, I might add more if I find something really worth it. I do pictures for fun, not money. I plan to shoot insects mostly.
My gear:
Nikon D600
180mm f2.8
50mm f1.4
helios 58mm f2
1.4x teleconverter (is that useful for macro?)
extension tube 60mm and soon a 2nd one ( Can I use both at the same time? Or maybe put a part of one at the end of the lens to act as a hood and use like 100mm of tube?)
reverse ring
and 72mm to 52mm step down ring... which does not fit my 52mm thread 50mm lens, I guess I need some sort of 52 to 52mm thing too
Here's an exemple taken with 50mm and 60mm of tube:
What's that in the center?
Thanks
