The Olympus and the Nikon microscope site were useless for info on OFN markings BTW. I found the info first on the ISO.org site than it took a couple of weeks for Nikon to finally confirm via email. At first the tech people that were helping me at Nikon were clueless about the new OFN marking. They had to walk out into the warehouse and actually pull stock to check it.
This is a Nikon Objective with the new OFN marking below. This is a newer CFI Plan APO 4X with 20mm WD.
OFN: Objective Field Number
Maximum field of view number of the eyepiece for which the objective is designed to be used.
The new ISO requirement indicates that objective lenses named Plan or with Plan as part of the name in the markings shall also indicate the objective field number on the body of the lens. The indication of the objective field does not apply to objective lenses sold before the year 2014.
Note: The objective in the image is newer but not the current version the CFI Plan APO Lambda 4X. The current has the Nano Crystal coating and is part of the new Lambda series.
Hope this helps someone.
