Boomblurt, welcome to the forum!
I'm currently using three Schott/Fostec Ace1 illuminators--good, workhorse units purchased second-hand. They use EKE halogen bulbs. They are on a hanging shelf, supported by ropes suspended from the ceiling, to avoid transmitting vibration to the macro rig (this is, as Craig noted, very important). While I also have flash equipment, I find myself using continuous light more and more. It is far more WYSIWYG than flash, and I find it more consistent and less problematic. Notably, this is the opposite of what I would have predicted two or three years ago.
If you go shopping, I'd recommend limiting your search to illuminators that have an iris. The ability to modulate the light without changing the color temperature is important. Using the dimmer on the unit has a dramatic effect on color temperature; on my units, if I set the dimmer dial to anything less than 80 out of 100, the light becomes too "warm" to correct in-camera.
I happen to like illuminators that have a shutter as well as iris, but doubt this would be important to most photographers. Units equipped with both shutter and iris are not so easy to find.
When you shop for light guides, I suggest you avoid the semi-rigid "gooseneck" types, which can be annoying. The flexible light guides that need to be clamped in position are much easier to work with.
g4lab wrote:I like FOSTEC Volpi and Dolan Jenner in that order due to quantity of light guides available. Schott are nice but expensive and the guides even more so.
Gene, would you be able to explain Schott/Fostec branding a bit? You likely know their history, and I do not. Presumably, these were once separate companies that have merged some time ago? Of the three Ace1 units described above, two are labeled "Fostec," and the other "Schott." Otherwise (and but for the fact that only two have shutters), they seem to be the same model. Certainly, they accept the same light guides.
A Dolan-Jenner unit that I have lives up to its name, as in "dolorous." My specimen is of rather poor build quality, and I would not recommend it.
--Chris
