Anyhow, ive been making a new stacking setup and basically completed it this weekend, was really excited to test the new setup as it would be more stable and precise, but when most of the parts were on the focusing block, the fine focus did not work
It worked before, but for some reason its not working anymore.
The block came of a vickers microscope, there is what seems to be a model nr on the block: m170865, but when i google this there are no results.
The fine focus gear/worm gear(im not sure what gear this is, but its the fine focus knob you turn, when you turn it,it moves outwards and after quite a couple of turns it locks up, though this seems part of the design) seems to run through the middle of a bigger gear, i did not open this yet as the screws holding it are really tight , so i will apply some q20 to loosen them up.
Here is a picture of the block:
Im worried that the worm gear or what ever it it that is on the inside there might be stripped. If anyone can maybe help with some info on this tipe of gear or which specific microscope it came from, or advice on how to try and fix this, it would be great!
Thank you
