http://www.photomacrography.net/forum/v ... 274#127274
what the best options are for 2x-3x magnification. I was only considering a few lenses, but the responses made me realize that I needed to open up the field to see what lenses I own worked best in that range. I decided to add several lenses suggested by folks (thank you!) that I already owned yet had not been considering.
Overall, the lenses are from 4 broad categories:
- Enlarger Lenses intended for wide mag range and tested in reverse
- Duplication Lenses optimized for narrow mag range
- Macro Lenses
- Microscope Objectives
In the last category, I was unable to test the Mitutoyo MPlan Apo 2x since I don't own or have access to one. What I did test is as follows:
Nikon 63mm EL-Nikkor in reverse orientation at f/4 (verified better than f/2.8 )
Rodenstock 67mm f/4.9 Scitex S3 in forward orientation (did not check reversed)
Nikon 50mm EL-Nikkor in reverse orientation at f/4 (verified better than f/2.8 )
Zeiss 74mm S-Planar at f/4
Rodenstock 75mm Apo-Rodagon D M=2 at f/4.5 in reverse orientation (verified better than forward)
Olympus MPlan 2.5x 0.05
Nikon 65mm Macro-Nikkor at f/4.5
Nikon 95mm Printing-Nikkor at f/3.3
Nikon 3x 0.09 MM / Measuring Microscope
Canon 35mm Macrophoto at f/4 (verified better than f/2.8 )
I used my Canon "HRT2i" camera (T2i with removed AA filter) for the tests. All lenses were adjusted for a ~10mm x-FOV for 2.4x magnification on Canon APS-C sensor. As usual, my subject is a Lincoln Cent, this time dated 1956-D. I centered the shots on the Mintmark.
I show one representative overall view below, followed by center and lower left corner crops from each of the lenses above. Here is the Overall shot:
Here are the Center Crops
Nikon 63EL
Nikon 50EL
Rodenstock 67S3
Rodenstock 75ARD2
Zeiss 74SP
Olympus MP2.5
Nikon 65MN
Nikon 95PN
Canon MP35
Nikon 3xMM
And here are the Corner Crops
Rodenstock 67S3
Nikon 63EL
Zeiss 74SP
Nikon 50EL
Rodenstock 75ARD2
Olympus MP2.5
Nikon 3xMM
Nikon 95PN
Nikon 65MN
Canon MP35
I put the lenses above in my opinion of worst to best for Center and Corner. Center and Corner were not consistent on any of the lenses. Here is my ranking by Center, Corner, and Overall Score:
Nikon 63mm EL-Nikkor................................ 10 / 9 / 19
Rodenstock 67mm Scitex S3 ...................... 8 / 10 / 18
Nikon 50mm EL-Nikkor................................ 9 / 7 / 16
Zeiss 74mm S-Planar.................................. 6 / 8 / 14
Rodenstock 75mm Apo-Rodagon D M=2..... 7 / 6 / 13
Olympus MPlan 2.5x 0.05........................... 5 / 5 / 10
Nikon 65mm Macro-Nikkor.......................... 4 / 2 / 6
Nikon 95mm Printing-Nikkor....................... 3 / 3 / 6
Nikon 3x 0.09 MM....................................... 1 / 4 / 5
Canon 35mm Macrophoto.......................... 2 / 1 / 3
The 95PN and 65MN both scored "6" overall but I judged the 95PN as slightly better since it was a bit more balanced across the field.
A couple of notes:
The 3xMM shows some extra illumination causing a "star" near the corners. I plan to re-do it to make sure the "star" goes away without the extra light. If not, it will drop to a lower ranking in the corners.
The 67S3 may need to be reversed. I will test it and see. The result is very disappointing and I am hoping it's just not optimized in forward orientation for mags above 1:1.
