I use T-mounts and have no chipped adapters.
Pau:
but if the camera doesn't detect a lens the LV image is MUCH darker than the actual picture: if you regulate the camera according the live image the picture will be badly overexpossed and if you regulate the camera to take the right expossure Live image will be VERY dark.
Not with my T3i. The live-view exposure "simulation" (which can't be turned off) gives a pretty close view of what the image will look like. If you are trying to photograph something really dark and your shutter speed is really slow (I think about 4 or 8 seconds or more) then the exposure simulation does not work well (perhaps at that extreme it can't provide enough gain to the LCD after a certain EV value... don't know).
ChrisR:
So if using flash, say, you can't see what you're doing.
Only if it is a non-Canon flash. With a Canon flash the LCD screen shows a proper exposure "simulation" since the camera knows there is a flash attached and powered on, and anticipates that the flash will provide correct exposure.
ANY flash disables EFSC. In fact anything at all shoved into the hotshoe (eg an RF receiver) depresses a switch which does it. And the contacts aren't enabled unless you press the switch - tried that too!
Not so. The only thing that disables EFSC is if a Canon flash is attached and
turned on. Then the camera senses the flash and will revert to the "close shutter/open shutter" operation which provides the flash sync signal. If you put a non-Canon flash on the hot-shoe the camera operates as if it is not there at all, whether the flash is powered on or off. The non-Canon flash will not fire from live-view because EFSC is still on, and no sync signal is given when EFSC is operational.
Unless using an external flash firing timer, to use flash in stacking, you can (only) turn Live View off and optionally use Mirror lock.
You can use a Canon flash and stay in live-view. It can be attached to the camera directly or via a dedicated flash cord.
Oh, the flappy rear LCD is handy. But on a stand it'll be the wrong way up if you want to see the top plate as well,
What information and settings can you not see even more clearly on the LCD (compared to the top plate) when you have the LCD display the "Qiuick Control Screen"?
