Simple Stackshot Controller
ichbtm
Post by ichbtm »
Hello,
This Software is a result of this post of Charlie Krebs,
This post made me pondering a lot on the hardware to implement, and I decided to use my Stackshot to do the camera travelling.
In addition, during my experiment, I decided that I needed to create a controller to automate the calculation of the Stackshot steps (based on the actual DOF at each step). So I did this Software controller.
In my momentum, I also recreated all stackshot native modes. In this software controller, they can be used in the same way but are much more intuitive.
I think this tool can interest some people so I put it online.
This tool is called Simple StackShot Controller and you can find it here :
http://www.macro-toolbox.com/index.php?page=download
don't hesitate to wander on the website to find the documentation.
So far, it has been tested under windows xp and 7 (32 and 64 bits) and a linux virtual machine (ubuntu 32bit) and I have good hopes that it could also work under Mac (but it would be a lucky strike) :) )
If volunteers want to test it and make me feedback, I'd be happy.
ichbtm
nielsgeode
Post by nielsgeode »
I installed the necessary drivers (on Win7 64bit) and when I try to start the program I immediately get: "Can't command stackshot. Is it powered?" It is switched on and directly connected to my PC with a USB cable.
When I swtich the stackshot on while pressing the config button and I launch the reflash utlity this is what I see:
Do you have any idea's what can be wrong?
Niels
ichbtm
Post by ichbtm »
hello nielsgeode,
can you contact me via email (support@macro-toolbox.com) ? I don't want to pollute this forum with my software support ;)
Your drivers are good and your stackshot has been found.
When you have this message it means that the stackshot didn't responded to it's first request.
Can you open a cmd prompt and navigate to the directory where Simple Stackshot Controller is unzipped and type the following command :
java -jar StackshotCtrl.jar 1>output.txt 2>&1
Then send me the file output.txt.
ichbtm
ichbtm
Post by ichbtm »
nielsgeode problem solved : his Stackshot firmware (StackShot 1-wire Vmon) was not the USB version ;)
ichbtm
Post by ichbtm »
I'm adding some stats calulation when you start an adaptive Bellows sequence.
These stats compares the use of the dynamic moving calculation against the use of a constant step size.
Here are some results with a 36x24 sensor, pupil ratio of 0.6, DOF OVERLAP of 1 and Max COC 2.5 (2.5 pixel size) :
Lens 21mm @f8 :
Adaptive Bellow Mode
There will be 72 steps processed.
Step Size at beginning will be of 0.409mm.
Step Size at end will be of 0.201mm.
If you use a constant Step Size of 0.201mm the sequence would have taken 104 steps.
Adaptive Bellows allows your camera to save 32 triggers.
Lens 21mm @f2.8 :
There will be 97 steps processed.
Step Size at beginning will be of 0.338mm.
Step Size at end will be of 0.129mm.
If you use a constant Step Size of 0.129mm the sequence would have taken 162 steps.
Adaptive Bellows allows your camera to save 65 triggers.
Lens 28mm @f8 :
There will be 107 steps processed.
Step Size at beginning will be of 0.286mm.
If you use a constant Step Size of 0.129mm the sequence would have taken 163 steps.
Adaptive Bellows allows your camera to save 56 triggers.
Lens 28mm @f2.8 :
There will be 305 steps processed.
Step Size at beginning will be of 0.101mm.
Step Size at end will be of 0.045mm.
If you use a constant Step Size of 0.045mm the sequence would have taken 468 steps.
Adaptive Bellows allows your camera to save 163 triggers.
As you can see there's a real gain of moves :)
The counterpart is that you need to transport a computer :roll:
The set up can be seen there.
The stats should be available is the next public version.
ichbtm
Post by ichbtm »
Hello
The last version of this app is available.
Now you can use a virtual rail that allows you to use this program as a Sensor/Bellows/Lens result calculator.
You just have to give some simple parameters :
- Sensor size and nb pixels
- Focal Length, aperture and pupil ratio.
Then, by playing with the position on the virtual rail, you can simulate a Bellows extension and you can have usefull values at any extension :
- FOV and Magnification
- DOF (front and back)
- Find needed extension to reach specific FOV or Mag or Hyperfocal focus or Infinite focus
- Effective fNumber
- Diffraction limitation (Circle of Confusion).
I'm always looking for feedback on a Macintosh... so if somebody with a Mac can tries it and tells me if the StackShot commands work I'll thank him a lot ;)
I think this will be the last version of this app (expect if I have to change something for Linux or Mac compatibility). I'm moving on an android version (as a tablet is easier to carry than a computer #-o )
