rjlittlefield wrote:Any chance we can get a picture of the objectives themselves? "Nikon 4 0.1" could describe several lenses with quite different characteristics.
I knew you guys would ask for a pic. Here you go:
Front row L-R:
Parco 4 0.15
Bausch & Lomb 48mm 0.08
Olympus M5 0.1
Technical Instruments 4 0.13
Olympus 4 0.1
Nikon 4 Plan 0.1
Nikon 4 0.1
Made In Germany 5/0.1
Back row L-R:
Canon 20mm f3.5-22 Macrophoto
Nikon Plan 4 0.13
Zeiss 20mm f3.2-f32 Makrotar
Nikon 5x Measuring Microscope (M26 mount)
Bausch & Lomb 48mm f4.5-22 Micro Tessar
Canon 35mm f2.8-f22 Macrophoto
Charles Krebs wrote:Ray,
That's a lot of work. Thanks for posting this. Can you give a brief summary of your impressions of winners and losers.
Several of the lenses could not even cover APS-C. I'd call these losers. So here are the losers, in order of worst to less bad:
Parco 4 0.15
Tech Instruments 4 0.13
Nikon 4 0.1 (which also vignettes a bit)
German 5 0.1
B&L 48mm 0.08 (which also had flare/hot spot issue)
B&L 48mm Micro Tessar (similar issue as above)
Olympus M5 0.1
The rest are able to at least cover APS-C, so I'd broadly call them winners. Here they are in my order of preference, decent to best:
Olympus 4 0.1
Canon MP35 (had to stop to f4 to get sharp image)
Nikon 4Plan 0.1
Zeiss Makrotar
Nikon 5x MM
Canon MP20
Nikon Plan 4 0.13
The most flexible lens was the Nikon 5x MM, which also has the interesting property of being effectively telecentric within the fairly shallow stack for coin imaging. There is no perceptible change in image magnification, and the stacker I used (CZP, still haven't graduated to Zerene) did not do any scaling compensation. Perhaps this is a quality of objectives for measuring purposes? The objective has a very long working distance, so it may be simply that there is very little perspective change over a distance that is short relative to the working distance? Whatever the reason, it was very convenient to do the stacks and had a completely different feel compared with the other objectives. The Nikon Plan 4 0.13 also has a large working distance, and had a somewhat similar characteristic.
