I did a stack with the wild 10x na .40 and then compared it too the 10x na .25 that i have.
I used 240 grit sandpaper, redish color, i know, likley not the best to use but this is what i had at hand. It was lit by a single led light, no diffusion (a tad on the bright side). Both objectives on bellows at 150mm extension.
Stacks were done in Zerene, pmax.
The results are quite wild!!!
Ok first a single slice of the wild 10 na .40 :
And now a single slice of the 10x na .25
And now the stacks:
1st is the wild 10x na .40.(i think i did not move in small enough increments with this but its done)
Center crop of the above @ 100%
Lower right corner @ 100%
Now the 10 na .25...
Center crop of the above @ 100%:
And lower right @ 100%:
Although the wild na .40 is "superior" to the na .25 in theory,the na .25 is far better and much more practical for the kind of thing that we do around here. Well that is my opinion
I also compared the wild 4x .10 to another 4x .10 and then took the na .25 and turned it down to about 4-5 x and compared it to the two 4x objectives
For now ill keep the wild on the microscope where it belongs.
