In the test below, TCA is, unsurprisingly, most evident in the corners of the image. Being transverse chromatic aberration, it is much easier to correct than axial chromatic aberration would be, if it were present (it is not). In this test, the TCA was removed with a single mouse click in raw conversion software (Nikon Capture NX 2).
Full image from D200 camera (APS-C sensor). The print in the test subject, the output from a laser printer, is very small (4 pt?).
Crop from lower left, without and with one-click correction. TCA is evident as blue fringe to the left of black print, and red fringe to the right of it.
The image was taken using a Mitutoyo MT-1 tube lens in conjunction with the objective.
--Chris
(edited to add a bit more explanation)
