Max RAM of my actual computer is 4GB but I plan to upgrade soon, First option is intel 2011 i7 3930K and 2nd option new intel 1155 i7 3770Krjlittlefield wrote:Twice as much as for one. ZS minimally takes 1551 MB for 21.0 mpx; a little more is better, say 2100 MB. So, running two in 4 GB would be very tight and might not work due to paging induced by other processes. But 6 GB or 8 GB should be fine.seta666 wrote:Also very interesting; how much memory is enough for two 21mpx stacks?
Apart of the obvious advantage of the 2 extra cores of the i7 3930K are there any adavantages on the intel 2011 platform regarding Zerene use? eg. dual channel vs quad channel memory
Rest of the system would be same regarding RAM, HDD, SDD etc... but intel 2011 system would be around 400€ more expensive because of extra cost of the processor and the need of a dedicated graphic card
In such system while running several stacks same time (2 or 3) would be better to activate all cores or tell each stack to use 4 cores (4x3=12 cores)?
Regards
Javier
