This is using the raw converter in Photoshop CS5 Extended, Version 12.0.4 x64. I've manually tweaked the settings for temperature and tint so as to match histograms for frames 5198 and 5214, the same ones discussed earlier.
Two things strike me.rjlittlefield wrote: What's interesting in the data I'm showing here is that the overall exposure is consistent even though the color balance shifts. In one frame the RGB values are [189,188,186] while in another frame they are [188,190,189]. This is averaged over the same 51x51 area in both images. It's the change in RGB ratios that is surprising.
It's true that the shifts are small in comparison to the +-0.5 resolution of a single pixel. But they're pretty large in comparison to the +-0.01 resolution of the average of 51x51 pixels, which is what the measurement reported. The differences are easily visible in the histograms and show up in the raw converter also, not just in the JPEGs.ChrisLilley wrote:One is that the shifts - by one to three units - are small in comparison to the resolution available in an 8-bit per component system.
Now there's a test that cuts right to the heart of the matter!Charles Krebs wrote:Do you have a second camera you could sync with the T1i and shoot something like a white wall (simultaneously with the single flash) to see if they both show the same shift?
That seems like a good possibility. Even with everything else stable, I wouldn't be surprised if there's some randomness just from gas dynamics in striking a 1/20,000 second arc.ChrisR wrote:Could it be you're getting about the right amount of charge (coulombs) but with a different duration?
Yes, several. What I don't have right now is time to continue messing with this problem.Got another flashgun, Rik?
Freshly charged Eneloop AA's. Recycle time < 3 seconds for full power, tested here at 1/32 power with constant 10 seconds between.What type of power source are you using with the 580EX II?
No broad conclusions here -- except perhaps for the usual one that the world is a complicated place.I think we need to isolate possible inconsistencies with your particular 580EX II before drawing broad conclusions.
