After few requests from microscopists on the forum, I will try to present you the aristoplan from Leitz.
I am a very lucky man to have found the scope at a very good price
Exactly my scope is the orthoplan 2, the first name of the aristoplan.
the only difference is there is not the arms holders on each side of the scope.
The scope is an universal scope, that allow you all sort of lighting, diascopic and épiscopic and fluorescenz.
Flash system
I have incorporated a electronic flash inside the base of the scope (arrows) in the path of the light. the flash is driven by the vivitar 283 thiristor and connected at the coolpix 995.
The setup is the same as Charles Krebs shown on his website some years ago.
The DIC system (ICT on the leitz scope)
Some years ago I found for some $ the good revolver for UKA condenser, with the 3 ICT prism inside. The person who sold it, didn't know the price of such item.
The ICT condenser system fit perfectly my old Dialux 20 scope, but I had not the ICT objectives.
Then I found the 25 and 40 ICT fluotar objective. That was good, but the problem of this objective is that you cannot use it as a classic brightfield objective because of the prism inside.
I have in my stock, some nikon and olympus wollaston or Nomarski prism
that I tried with others objectives. I succeed in finding good combinaison.
When I found the aristoplan on Ebay, I sold my Dialux20 and the ICT objectives at a good friend. I just kept my UKA condenser and my better objectives with their homemade analyser prism.
Unfortunately the scope was not equiped with the ICT objectiv turret. So I built a sort of slide holder where I put my homemade wollaston DIC slider.
I need 3 wollaston slides to use all my objective from 6,3 to 100x.
It was great but I was looking for the ict turret.
I found one 1 year ago, without the prism, but it was not so important. What I wanted, was to change quickly of prism without the risk of crash one on the floor.
Unfortunately, the ICT turret was made to fit the Aristomet nosepiece and not for the aristoplan. So with my good old Dremel I spent two days to modify the nosepiece and the ict turret. My poor english do not allow me to explain what I do, but I sweated all the time, modification was not reversible.
Then I adapted the prisms inside the turret
Thanks to the button, you can adjust the position of the prisms to change the background.
I have the polariser fixed, and I turn the 1/4 lambda plate to adjust background to.
And below the UKA condenser I made a slide holder where I can put an homemade Lambda plate to have the colorfull background.
The analyzer is on the slide between ICT turret and trinocular head.
It is a great scope (and heavy), but it is perfectible, and it is very hard (and expensive) to find all the accessories, but I do not regret at all my purchase.
Jean-Marc
