Ever thought about making an own darkflied condensor by attaching an filter with a black spot in the middle on an for example old analog ~50m lens and putting the lens on an diffused light source?
The field could be adjusted by focusing the lens, by the size of the "black spot" on the filter ring and by the distance between the black spot and the lens.
Should'nt it work perfectly as darkfield condensor?
I tried it with an old defective M42 28mm F2.8 lens, but contrast was bad, as the lens had bad fungus, I used only reflecting aluminium foil as "black spot" and I can't find any good flat light source.
