Phil, thanks for your sharing your experience with the Maha charger. Much appreciated! Your information will likely save me money.
DQE wrote:I think the only time I've used the battery reconditioning feature is when my partner was having trouble with a very infrequently used set of Eneloops for an occasionally used LED flashlight. Even then, I'm not really sure it was necessary to use the reconditioning feature, but it seemed like a good way to reassure her that I'd fixed her flashlight.
Ah, seems to fit into my limited understanding. The old NiCad rechargable batteries had serious memory issues, and a fancy charger had a better chance than a cheap charger of keeping them at peak function. But modern NiMh batteries, such as the Eneloops, seem to have substantially fewer problems with memory and conditioning, so perhaps a fancy charger is not so important, so long as a simple charger is slow enough to avoid heating the battery, and scales down to trickle charge when the battery is full?
DQE wrote:I personally enjoy the Maha's digital readouts of the recharging cell's voltage and the current being used, but have never taken any actions based on those readings. Every time I put a heavily discharged set of cells in the unit, they reads about 1.35 volts for each cell, and when they are recharged, they all read about 1.49 volts. There doesn't seem to be much difference from cell to cell when used in a 4-cell flash gun. A simple on/off light on the charger would do just as well, although one can guess from the voltage about how close to recharged a given cell is.
I also love information, which is why I've considered getting one high-end charger. But your feedback lessens thiis craving. It's interesting that your measurements of voltage drop show it to be pretty small for the Eneloops. I'm not surprised, given the even output I've observed. It would be much more interesting to have additional measures beyond voltage--though with my limited understanding of such matters, I'd have to do some homework to understand other measurements, if they were available.
DQE wrote:Having more chargers would be more helpful to me than having only one fancier charger, I now think.
I definitely understand this, as I use Eneloops for lots of things (macro photography, "strobist" style portrait photography, headlamps for hiking/climbing, walkie talkie radios, etc). And I like to go into every shoot with a fleet of fully-charged Eneloops. Even if I think I've used only a few percent of the charge of my Eneloops, between shoot, I like to restore every battery to a fulll and predictably charge. So recharging a bunch of Eneloops at once is, to me, a big convenience.
DQE wrote:About the only time I've had slight concerns about my Eneloop AAs was when I accidentally left my 3-watt LED flashlight on for about an hour. The batteries became almost too hot to hold, although they showed no signs of swelling or anything. They recharged normally and I couldn't immediately detect anything wrong with them. Probably the heat was just a predictable effect of a fairly high current sustained discharge in the enclosed space of the flashlight.
I have a parallel experience--when I shoot (typically) 400 full-power flashes from my Nikon Speedlights, then pause to change Eneloop batteries, the Eneloops I remove are, as per your experience, almost too hot to touch. I imagine that this compromises the life of the Eneloops, but I haven't yet seen a negative effect. And if the life of the Eneloops is cut by half, 3/4, or even more, they will still be a bargain against alkaline batteries. But I have no data, yet, on how--if at all--the life of Eneloops may be reduced by heating during discharge.
By the way Phil, your description of your partner's headlamp strikes a chord with me. I have two Zebralights, each of which takes a single AA battery. These lights are said to be optimized for Eneloops, and in my experience, Eneloops do shine in them much more brightly, and for a much longer period, than alkaline batteries. Many of my climbs/hikes go into the night, and my norm is "you fall, you die" situations. So it's basic to my plan to have two high-quality headlamps, each containing a topped-off Eneloop battery, along with a spare Eneloop battery for each. A couple of years ago, I hiked across the Grand Canyon by starlight; on this hike, I didnt actually need my headlamps, but I was glad to have my full headlamps/spare-batteries setups in my pack just in case. Eneloops are good enough that I stake my life by them--and as can be appreciated, I don't say this lightly.
Cheers, Phil--and thanks again for sharing your experience--I much appreciate it!
--Chris
