I think it's great. It's totally solid. In fact the only part of my rig with some play is the hotshoe/flash.
Extreme Macro Setup by Marc Lorenz, on Flickr
Variable friction power arm by Marc Lorenz, on Flickr
I have all of those. As stated before, bangs for the buck they are good but are not the highest quality. Examples - the clamping bolt on the superclamp is wobbles but works perfectly well, the friction arms are not the smoothest on the world but work perfectly.Craig Gerard wrote:I cannot comment on the overall quality of these items; but I have purchased some and will let you know.
The prices have dropped since I last looked, there are quite a few out there now, however, they look very similar, if not identical. Prices vary depending on the seller.
Three particular items: two articulating variable friction arms and the third link is to what appears to be a handy, small super clamp.
11" Adjustable Variable Friction Arm
http://cgi.ebay.com/250820173077
7" Lightweight Adjustable Friction Arm
http://cgi.ebay.com/260803435658
Small Super Clamp
http://cgi.ebay.com/260815979398
Here is an image of the arrangement (Custom Brackets Mini-RC and Variable Friction Arm).
I could have taken a number of images showing the various positioning capabilities of the Variable Friction Arm; but suffice to say it is very accommodating and has considerable 'reach'. It will comfortably position the flash unit beyond the front of a fully extended MP-E, a bellows or permit appropriate positioning when using a shorter lens such as a 50mm. Positioning changes can be easily made within a matter of seconds and the flash can be located in almost any position required.
P.S. This is not the diffuser I would normally use with the 270EX.
