On another forum I have seen posts where people have had bad luck with
inexpensive fiber optic illuminators. I don't know whether they were this model.
I have been using them and been a student of them for a long time.
I recommend FOSTEC (and Schott FOSTEC) if you live in the USA. A lot of these were sold and they are available and also many different types of
light guides are available. (that may or may not be of interest) FOSTEC stands for Fiber Optic Specialties which is what the company was originally called.
Like this one
Just search ebay for FOSTEC. Schott FOSTEC are the same,, Schott bought the company. Schott Illuminators are very high quality but always more expensive and much harder to find light guides inexpensively and the connection between the illuminator and guide is more expensive and robust and non substituteable. They are made in Germany and correspondingly more expensive and much less available on ebay.
There is a swiss maker Volpi whose products are swiss quality.
There is a Boston area maker Dolan Jenner also widely available and reasonably priced. They were probably the very first on the market back in the day.
There is also a US company called Chiu which has an illuminator called the Lumina. This was sold under many different liveries and there are two FOSTECs shown on ebay right now that are really Chiu's . Maybe Schott bought them too.
These things last a very long time. The only things that wear out are 1) the bulb. Higher color temp = shorter bulb life hours 2) the receptacle that the bulb plugs into is an expendable item. It needs to be replaced every X number of bulbs because the pins of the bulbs are so hot that they oxidize and draw the temper of the initially springey contacts. 3) The cooling fans have a tendency to wear out in thousands of hours of use. This is not as common as "2" and the fans are easy and cheap to replace.
A lamp head with an iris diaphragm is generally desireable but raises the price. So is DC regulation of the filament. For the latter FOSTEC has an optical feed back module.
