According to my limited experience, this seems not to be an issue with the EP-2.Harold Gough wrote:In both cases, I have some concern about lens-recognition issues by the camera body.
Harold
I now have one of the RM-UCI types. It was one of the cheaper ones. It would not work until pushed in very hard to the port but then works OK.AndrewC wrote:He means you need to create a IR or electronic adapter. In the Olympus case it is an electronic cable RM-UC1. Actually, "electronic" is being generous - it is probably a simple mechanical switch shorting out two pairs of contacts.Harold Gough wrote:Most of my references to cable release are to the mechanical OM one. The camera bodies have some kind of remote release provision.elf wrote:Camera manufacturers have forgotten that cable releases actually work. Most do not have any way to connect a mechanical cable release. You'll need to make some kind of an adaptor for the camera end.
Harold
The Pen series of cameras have an excellent focussing aid by way of the magnification option ie, you can magnify the on-screen image or VF-2 image up to 10x for critical focusing. It's just a bit clunky when reverting back to normal, but in macro work, probably doesn't matter so much.Harold Gough wrote:
What I find to be an absolute pain is the lack of focus aids, such as split image and the various screens (e.g. 'cross-wires') I use with film. The problem with mirrorless cameras!![]()
Harold
Ray,OzRay wrote:Harold
You're just going to have to use either a monopod or tripod to get things sharp for this sort of thing at ISO400 and f11. Handheld is simply not going to cut it. Also, subject movement is going to be unavoidable at those settings.
The VF-2 will help significantly, but it won't be a panacea for movement etc. You're still going to need support.Harold Gough wrote:Ray,OzRay wrote:Harold
It's probably the holding at arms' length which is getting to me. I find it extremely awkward and tiring. I'm still waiting for the VF-2 to arrive.
Harold
