However, I find that turning the adjustment knob on this unit is extremely difficult. My first thought was that the the grease has polymerized, and indeed, under good light, I can see green gunk in the threaded rod attached to the adjusting knob.
I presume I can fix this by disassembling the unit, cleaning the threaded rod in solvent, and then greasing it with proper grease. But disassembly is not obvious—so before I start blundering about, can anyone with more knowledge give me any advice? How does one remove the threaded rod? What is a good solvent for cleaning the threads? What is a good type of grease for applying to the rod after it is clean?
This is not my own unit, but a file photo of the same model:
In advance, thanks!
--Chris
