Laborlux condenser mount
Tom Jones
Post by Tom Jones »
Is anyone here familiar enough with the condenser mount on a Leitz Laborlux K or 12 to be able to tell me how to remove the condenser? While assembling scitch's pile of parts several weeks ago, we wanted to swap condensers between two scopes. It looks like a slide-in dovetail or something close, and should be easy to remove, but neither of the condensers could be coaxed loose.
Since I wasn't familiar with that particular scope I wanted to get a manual or some instructions before we put too much muscle on them.
Since I can't find the correct manual anywhere, what am I missing on the condenser attachment? Is there a locking screw hidden somewhere? Are they probably just stuck, or are they really not removeable. One scope has a darkfield condenser which isn't all that useful for normal observation in a classroom. We need to get our act together before finding a standard condenser to replace it. Thanks!
Tom
scitch
Post by scitch »
Thanks, Tom.
Here's a picture of the darkfield condenser.
Online
g4lab
Post by g4lab »
That condensor should slide right out. It may be that the grease used to lube the dovetail has polymerized and turned into cement.
A few drops of dry isopropanol perhaps with a little acetone added placed right on the seam may help break it loose. Some penetrating oil could be applied very carefully.
You could VERY carefully warm it a bit. Or keep gentle pressure on it for a while. If there is a locking screw it should be visible, not hidden. But I don't think there is one.
Most Leitz condensers are removeable on a simple dovetail sledge. Though I can see part of what looks like a sledge, I'm not sure about this one. I see a small silver knurled knob slightly out of focus at the back on the left at the same level as the condenser centring screws and I'm not sure what that does. Also I see some features on the surface of the condenser which don't look compatible with a simple pull out sledge. Some more photos from above and the sides of the condenser would help confirm. The condenser will certainly be removeable, it's a matter of finding out how.
Perl
Leitz Cond
Post by Perl »
Hi!
Turn the silver knob backwards and pull the Condenser out
( Silver knob have hooks that look it in position )
Regards
Pär Lundqvist
Sweden
Tom Jones
Post by Tom Jones »
Thanks everyone for the suggestions. Par, we loosened all the screws and it still didn't want to move, so I suspect g4lab's idea about the polymerized grease is probably correct. We'll try the acetone or penetrating oil on it next time.
Mike, could you post a couple more shots of the condenser mount? Maybe Dave can see something hiding we missed.
Thanks.
Tom
Perl
Post by Perl »
Hi
Do not use aceton - to strong
Isopropanol or ethanol is better
Put it in the place where dovtails run
and let it soak in for 20 min then try carefully
Regards
Pär
scitch
Post by scitch »
Yes, I'll try some of the suggestions and then take some more pics. I think it's a combination of the silver knob and the dry grease. I've played with that silver knob, twisting, pulling, pushing, etc and it wouldn't come loose. It has a dot on it and there's a dot on the scope that can align, but it still won't come out.
I'll wait to get together with Tom again before applying any chemicals to it.
Perl
Post by Perl »
Hi
Silver knob shall not come out just be turned 1/4 backwards
Regards
Pär
scitch
Post by scitch »
OK, I got it out. It was stuck, but now it slides in and out and locks and unlocks. The small silver knob turned fully counter-clockwise is locked. Dots lined up is unlocked and it slides straight forward.
Thanks to all who offered advice.
scitch
Post by scitch »
I also figured out why I couldn't get the dark field condenser to work on the diatoms . . . "oel". A drop of immersion oil should make a difference.
