http://www.photomacrography.net/forum/v ... c&start=30
Sure. Most remotes just require you to pull two signal lines to ground - first one focuses, second one shoots. The Panasonic has a 4 pole minijack but only actually uses two poles. Inside the remote is a resistor ladder - you need a specific set of resistances to convince the camera that a) the correct remote is connected b) you want to focus c) shoot. 36k, 3k and 2k if memory serves me well. The paranoid side of me thinks they chose those because they aren't commonly available ! Probably just forms part of a voltage divider inside the camera feeding into an A/D convertor on the CPU. Just need to find five minutes to draw up the circuit diagram then I'll post it, though I'm sure it is already out on the web somewhereg4lab wrote:Will you be sharing those details? Are they easy to implement?Downsides: pesky Panasonic don't have a simple remote release (but that only took me about 5 mins to reverse engineer and adapt to my stack controller),
http://www.instructables.com/id/Panason ... r-Release/
The simplest way to get there is to buy an eBay cheapy and then adapt it. The 4-pole minijacks can be hard to find. My adaption is to use optoisolators to short out the resistors (remember there is a current path through the ladder and optoisolators are basically diodes so need to be connected the right way round). I then built the switching network into a mini enclosure with a stereo jack which plugs into my controller. I have a similar one for the Nikon interface so I have a modular system which lets my controller drive the Panasonic or Nikon cameras and I could easily adapt to any other camera:
Controller > stereo jack with 5V signals + ground > switching network > camera specific connection (eg 4pole panasonic or Nikon 10 pin). Here's how the Panasonic module looks. There are a couple of leds on the signal lines just so I can see the module is working.
Panasonic G cameras have instantaneous live view because they have no optical viewfinder - no mirror so physically smaller. Trouble is that they have decided to use the HDMI connection (no other video port) to just display during review. Or I'm missing something which wouldn't be the first time.the DMC has live view and an HDMI connection but does not relay the live view to HDMI, gnash
Does it send the live view out a regular video port?
Is the live view delayed?
Edit: had a quick search /refrsh on the HDMI liveview and waddya know, Panasonic just released a new camera that can do that: http://www.engadget.com/2010/09/21/pana ... ovie-mode/
