Is it possible to use a 70-200mm as A tupe ?
ghaith
Post by ghaith »
Hi
I have a question . Is it possible to use a Canon 70-200mm F2.8 With nikon cfi plan 10x objective Lens ?
What are the Ring to be purchased to install the 10x objective lens ?
Now I use a Canon 100mm lens Without any problems But I do not know if it was possible with 70-200mm
Welcome aboard!
Yes, there have been good reports using a Nikon CFI Plan 10X objective with Canon 70-200mm f/2.8, especially at the long end near 200 mm.
I believe that lens has a 77 mm filter thread.
I am not aware of a one-piece adapter that will go from 25 mm for the objective all the way to 77 mm for the Canon 70-200.
So, you will need an ordinary step ring plus the objective adapter.
Because you are already using a Canon 100, I guess that you already have a one-piece adapter from 25 mm to 58 mm, or perhaps a two-piece setup such as 25 mm to 52 mm plus a step ring for 52 mm to 58 mm.
For the 70-200, I suggest just getting another step ring, either 77 mm down to 58 mm if you currently have a one-piece adapter, or 77 mm down to 52 mm if you are currently using the two-piece setup.
ghaith
Post by ghaith »
Thanks for your help :)
