Nice scope!
There are different kind of phototubes that fit the upper port dovetail mount.
- Simple monocular tube 25mm diameter to mount an eyepiece and a camera adapter over it, its the simpler, less expensive and older option (black or gray models).
Shown here:
http://www.microscopy-uk.org.uk/mag/ind ... w-pm3.html
- Focusable monocular phototube, the setup will be similar than with the former one but it allows for fine tuning parfocality. The lower part is to mount a 40mm adapter and the final part to hold the eyepiece is also 25mm (gray)
http://www.photomacrography.net/forum/v ... p?p=189160 7th picture
- Dedicated tubes with some kind of camera mount (gray).
http://savazzi.net/photography/zeissadapter.html
AFAIK all of them work afocally: a KPL or S-KPL eyepiece and a lens over it. This is necessary because Zeiss objectives need compensating eyepieces to complete the objective correction.
The formula for afocal systems is
eyepiece magnification X camera lens FL /250
The recommended total relay magnification is about:
For FF 2.5X, for APSC 1.6X and for 4/3 1.2X
To mount on a microscope you want a camera that doesn't induce vibrations. Most (not all) Canon EOS will do, also few Sony NEX and A and newer Olympus will fit
