Another Newbie question.
pinhole
Post by pinhole »
Concerning objectives. What is the difference between a PLAN & an INFINITY PLAN objective??? Thanks folks, pinhole
f269 an' be there!
johan
Post by johan »
An infinite objective requires another optic in the optical path to make photos whereas a non-infinite plan does not. Frequently this other optic required for infinite objectives provides correction of some form.
Plan means flat field.
"Infinity" means it's designed to focus at infinity, in other words not directly on to (say) a sensor. So it needs another lens to "accept its output" which seems to be coming from infinity, and focus that onto the sensor.
The non infinite lens is designed to focus at typically 160mm from the lens, so it can go straight to a sensor.
Both are just lenses, and will form an image in either configuration, but noticeably not as well as if they're used as intended.
pinhole
Post by pinhole »
Thanks much Johan & ChrisR. Cheers, pinhole
f269 an' be there!
pinhole
Post by pinhole »
So, another newbie question.
I'm under the impression a PLAN objective would be considered better for crystallography??? Thanks folks, pinhole
f269 an' be there!
What kind of crystallography do you plan to do?
For photography yes, at least if you want to take single frame (no focus stacked) images. In general Plan objectives are from middle range series and better corrected than no plan ones.
For some very specialized techniques like using Fedorov stage the only available objectives are in most cases not plan corrected and to for the study of some optical properties like the optical sign when you look at the objective focal plane it likely would not matter.
pinhole
Post by pinhole »
Howdy there Pau.
Yeah, just single frame imaging of dried solutions, etc.
You've been most helpful, thanks.
Cheers from Wisconsin, pinhole
f269 an' be there!
