I'd like to try the Vickers first, because it has 3 objectives (3,10,40?) and a quartz wedge.
The Leica is a basic model, which now only has 4x and 10x objectives (I'll be looking for something higher).
I have two heads for the Vickers, one with a 29mm diameter tube and the other smaller, which looks "standard".
Does anyone know if these will use "compensating" eyepieces? I have two of the wider ones, both 10x, but one looks normal to me whereas the other has no stops in it, the glass is full diameter. Maybe one is high eyepoint, I don't know yet.
If the answer is no then I'll arrange a camera on a tube for direct projection.
Next question: would the higher magnification/NA objectives have been available in both "met" (no coverslip) and 0.17 versions of "Pol"?
The Vickers is very like this. Tha caption is M14 but I was told mine's an M70.:
http://earth2geologists.net/Microscopes ... 14_pol.JPG
Pol scopes, Vickers M70, Leica somethingorother
