Some trouble with stacking artifacts...
JH
Post by JH »
Hi Pau
OK - If I do not remember wrong I get similar results at 1/200 sec, thats why I started to use the studio flash at only 1/100 sec. This is never a problem with my Canon flash but it eats batteris and gets quite hot when used for stacking.
Interesting video in your link;
Pau wrote: Here you have a link to a most interesting video illustrating how the shutter works:
http://www.photomacrography.net/forum/v ... hp?t=27819
Regards Jörgen
etalon
Post by etalon »
Hello back,
now I could do some tests with the new camera, Olympus OM-D EM5 mk2. It´s a very good camera and compared to my 5D2 pretty tiny. The camera have only a quarter FOV to the 5D2 but on this area a three times higher resolution in high res mode! For a 10x objective, this is pretty much oversampled, but for 20x and 50x it would be ok...
Well, the upper left corner is a very little unsharp than the other corners, but I can deal with it. Because of the oversampling, structures are pictured soft, but at usable resolution it looks all pretty sharp. There is no noise and no vibration during work.
I did also some Sorbothane damper under the breadboard (as Rik mentioned).
Here the test shots:
All corners and the middle at 100% crops, ZS DMap stack, 63MP high res shot:
And the entire FOV downsized to 1024px:
I´m pretty statisfied with that camera. Now I going to do some photography...
:D
Cheers Markus
In fact it will be just the opposite: Usually you will get more resolution on the subjet side (higher NA) but less sharpness on sensor due to smaller effective F number (for usual objectives, of course)
etalon
Post by etalon »
Ok, thanks for clarification.
Now I can present the very first result with the new combo. I´m not sure, what it is, but I think it´s gypsum. FOV is ca. 1.7mm, ZS PMax, 130 layer stack, Mitutoyo Plan Apo 10x, Raynox150 reversed, Olympus OM-D EM5 mk2 in high res mode:
Cheers Markus
etalon
Post by etalon »
...and here we go...
Langit xx, FOV is ca. 1.7mm, ZS PMax, 72 layer stack, Mitutoyo Plan Apo 10x, Raynox150 reversed, Olympus OM-D EM5 mk2 high res mode:
Cheers Markus
JH
Post by JH »
Looks fine to me.
Regards Jörgen
Withan image what, 8000 pixels wide(?) it would e nice to see a 100% crop ;)
1024 hopefully doesn't do it justice.
etalon
Post by etalon »
Thank you, Jörgen!
Chris, here is an 100% crop from near the middle of the pic:
The original have 63MP. That is a very little to much for the forum... ;)
Cheers Markus
That's better, thanks :)
By the way, they say 40MP
What dimenson images does the camera produce in high res mode??
Anr EIGHT shutter-firings per frame :shock:. What's the shutter life?
You could be the first to do a 10,000 image stack. Before stitching :D.
etalon
Post by etalon »
It's 40MP for JPG. In RAW you get 63MP frames... :D
In RAW I get 9216x6912 pixel resolution in high res mode. But the files are pretty huge - 320MB as TIFF. Therefor stacking take a long time, also with a fast machine...
I don't know about shutter life, but there is no mechanical shutter I use, so I hope there is a pretty long life time. :D
For high resolution the camera take 8 pics and move the sensor between each shot for a half pixel amount. Than the camera calculate a high res frame from that 8 shots.
I like the camera for photomicrography...
:D
Cheers Markus
etalon
Post by etalon »
...and one more:
Vanadinit x, FOV is ca. 1.7mm, ZS PMax, 64 layer stack, Mitutoyo Plan Apo 10x, Raynox150 reversed, Olympus OM-D EM5 mk2 high res mode:
Cheers Markus
pierre
Post by pierre »
Very fine result with your Langit xx Markus :shock:
The trouble with stacking artifacts... seems gone ;)
Well done.
Regards
Pierre
etalon
Post by etalon »
Thank you Pierre!
The trouble with stacking artifacts... seems gone Wink
Yes, it seems like most of them are gone... :D
Here is the evidence:
The Uranophane xx I posted with problems before. FOV is ca. 1.7mm, Helicon C, 93 layer stack, Mitutoyo Plan Apo 10x, Raynox150 reversed, Olympus OM-D EM5 mk2 high res mode:
Cheers Markus
pierre
Post by pierre »
Great work indeed.
You are ready to open your own gallery Markus :)
Regards
Pierre
etalon
Post by etalon »
Thanks Pierre.
Than I´ll go on to fill my gallery...
Azurite x, FOV is ca. 1.7mm, Helicon C, 63 layer stack, Mitutoyo Plan Apo 10x, Raynox150 reversed, Olympus OM-D EM5 mk2 high res mode:
Cheers Markus
