Procedure for using projection eyepieces
hi Charles, if you remove the internals from the UFX system wouldn't you just need the camera shutter then since it would just basically be a bi hollow tube that will attach to a Nikon camera? I don't use flash, so certainly I guess how you shoot could be a factor in how to adapt things and certainly you have it figured out pretty well according to your results
