A couple of questions and thoughts come to mind...
Which Nikon 10X objective is this? There are dozens out there with various specifications. (A picture might be best). Your sensor format diagonal is about 27mm. Most finite Nikon (160mm tube length) objectives were intended to provide, at best, a quality image of about 20mm diagonal. Certain ones that were intended for use with super wide-field heads were designed to provide a quality image circle of about 26-27mm. That's not to say it is not possible to get a good image out to the corners with a non-super wide-field design, but it is not to be taken for granted, and must be tested to see how well it works.
When you say "~170 tube" are you referring to the distance from the objective threads to the camera sensor? The objective was designed for a 150mm distance in that regard, but using slightly more (like 170mm) might actually be better if the corner quality is not that great. Compare the center to a corner. The center almost always will look somewhat better, but the difference should not be extreme. If the center is good but all four corners are not, it is most likely a case where the objective is not providing an adequate size image.
... live view and 580EX flash...
Flash should eliminate most vibration problems (if the power level is turned down resulting in a very short flash duration). But even with flash it is still a very good idea to use technique that will minimize any potential sources of mechanical vibration. Are you shooting directly from from live view? If so, you should be aware that when doing this with a Canon flash attached, the shutter must first close and then re-open to start the exposure. From an "anti-vibration" standpoint is is better to not shoot directly from live-view when using flash. After getting everything set, turn off live view. Use the camera mirror lock-up. For each shot release the mirror up, pause, then take the picture. This way you only have one mechanical shutter motion before the flash fires.
If you are working in a room where you can turn down the ambient light levels it is also possible to set the flash to "second-curtain sync" and use a long exposure (such as 1/2 or 1 second) which then would allow any shutter vibration to dampen out before the actual flash exposes the picture. (Just be sure room light levels are low enough to avoid registering an "ambient light image" on the sensor. All registering exposure light should come from the flash).
110 stacks at 2um interval
This is "overkill" for a 10X objective. The steps can be larger and fewer images used. (This should not be the cause of any "unsharpness" you are seeing, but you are making more work for yourself). It can vary somewhat depending on the NA of the objective, but at 10X you are certainly safe at a 4 micron interval, and probably just fine at an 8 micron interval. Run your stack using every other image or every third image and compare results.
