Spring Leaf
Simon W
Spring Leaf
Post by Simon W »
Spring has sprung in Oz, a lovely time. Weather oh so unpredictable in Melb., as usual...
Per Rik's tips, I've re-watched the Zerene instructional videos and using Rik's suggestion, I found this 50 pic stack editing much easier (although it's easier than the louse claw, not quite as deep).
I processed via both methods, Pmax and Dmap, then used one as the base and applied the other as necessary. I was happy with the result, but then noticed the strange artefacts from Dmap, so re-did the Dmap using a higher contrast threshold, then re-applied that output as I saw fit. Cool!
Craig advised me to try some sorbothane mounts to minimise any vibrations, now that the scope is on a chopping-block which is on the sorbolene, YES, it's pretty well impervious to any vibrations.
This first image is the final result of all the editing. Taken with my new 4x apo :D Brightfield. Quite pleased with the detail coming out across the focus range:
10x leaf final zerene version by Simon__W, on Flickr
Here is the Pmax, I liked the detail in the stalk, so used that:
10x leaf-PMax by Simon__W, on Flickr
Here is the Dmap, preferred this for the patterns in the chloroplast area, however notice the artefacts. I can't show you the reprocessed Dmap image I used to remove the artefacts, but the first final result show where I was able to correct for those. I looked and looked at individual images, only a few were worth applying for the fibrous detail, in the main the Dmap and Pmax combo worked really well, so thanks Rik!
A new Ikea's opened up in Springvale down here, so I'll pop over there and get some Janso's soon. I know I can do much better re. lighting, but step by step..
2011-09-13-13.18.04-ZS-DMap by Simon__W, on Flickr
Simon W
EOS 5D Mk 3; Olympus BH-2; Zerene Stacker
Melbourne, Australia
Craig Gerard
Post by Craig Gerard »
Simon,
Interesting bioscape :)
Simon W
Post by Simon W »
Yes, I love the patterns in many of our images.
Simon W
