another Peltigera. This one has 2 photobionts.
a) green algae in the lobes
b) cyanobacteria in cephalodia situated on or near the veins on the lower surface
- Habitusfoto. Thallus green, ~ 2 cm diameter. Lobes single, 0,5 - 2 cm.
- Lower surface. Veins with tomentose surface and scattered black cephalodia.
- Lobe cross section. Beneath the paraplektenchymatic upper cortex follows the layer with the symbiontic green algae (Coccomyxa). Under this layer we see a layer of loose ordered mycelium. There is no lower cortex. The cephalodia contain the second photbiont, Nostoc spec. .
- Closeup cephalodium with paraplektenchymactic cortex
- Cross section apothecium. Staining with Lactophenol-Methylblue-Acidfuchsin.
- Ascus Peltigera type, 55 x 11 µm, apex with K/J+ blue annulus. Spores 3 septated, 8 per ascus, 23 x 5 µm. Staining with Lugol.
