Wasp antenna
bernhardinho
Wasp antenna
Post by bernhardinho »
Hi folks
starting a series of wasp anatomy
So here is the antenna for a start
Bernhard
NikonUser
Post by NikonUser »
Bernhard:
It would be nice to see an image of the entire wasp, or at least a species name.
NU.
student of entomology
Oliver Wendell Holmes, Sr
Nice idea Bernhard. But your Stinger is much sharper... :-k
You weren't doing this during the exposure: :-({|= ??!
bernhardinho
NikonUser wrote:Bernhard:
too late, it's in pieces now :oops:
Bernhard
bernhardinho
ChrisR wrote: But your Stinger is much sharper... :-k
I beg your pardon...?? \:D/
Chris: I cut the wasp in pieces and prepared a couple of slides in order to get some insight in various parts of the insect. The mountant is Canada Balsam. Now, the tissue of the stinger is rather soft and it flattened nicely with moderat pressure applied to the coverglass. Hence it was possible to get some decent shots that I combined in a focus stack. The antenna is obviously made of much harder chitinous stuff that could not be squeezed at all. So the layer of mountant is rather thick which lessens resolution a bit. Although I tried to capture some detail of the antennas surface (not TOO sucessfully), the issue here turned out to be much more the play with contrast and colour. In this way I sort of like the pics. What else should I say ? :roll: :D
Cheers
Bernhard
Are those full frame shots?
Wouldn't you expect more in focus from a stack?
Looking at this which featured in Beginners Macro Stack , if you blow up a small section the joint between the sections of antenna is quite sharp (no sharpening has been done)
Have you any more pieces?!! Maybe you could try one just laid on top of the stage?
Hhmm... I assumed these were not stacks, since the focus trails off gradually.
But I didn't think about it very hard because I was more interested in the surface texture of the antennae.
I'm accustomed to antennae (in general) being covered with bristles and hairs, albeit sometimes very small. These seem to be basically smooth but knobby.
Of curiosity, I just now rechecked one of my many Polistes dominulus specimens. At 45X under a stereo scope, it seems quite similar to what I see here. But quite different from the NikonUser's yellowjacket HERE.
By the way, I agree with Bernhard about the lighting and colors -- they are easy on my eyes.
bernhardinho
ChrisR wrote:Are those full frame shots?
Rik said it, the antenna wasn't a stack but single shots taken with a Coolpix 990 mounted on a compound microscope!!
See ya
Bernhard
Harold Gough
Post by Harold Gough »
bernhardinho wrote:too late, it's in pieces now :oops:
You could try some stitching software. :smt101 :smt102 :D
Harold
Oh, right, the stinger was soft so it was squashed flat and you did do a stack of that, but the poor antenna was deeper and you didn't stack it :o
Yes that would account for it!!!
bernhardinho
ChrisR wrote:Oh, right, the stinger was soft so it was squashed flat and you did do a stack of that, but the poor antenna was deeper and you didn't stack it :o
Am I mistaken or do I trace some hints of irony there :?
Mind you, the stinger still wasn't flat enough to get an entire sharp image all over the field so I made a focus stack, not a DOF stack!!
In the case of our poor antenna it would not have made sense IMO to do a stack. It would have looked artificially flattened which I tried to avoid.
Does that make any sense to you? :smt039
Cheers
Bernhard
