Razor blade edge. Reflected DIC
One reason I dragged out the BHA was that I finally got a DIC prism for reflected light, and wanted to give it a try. I only have one, and it is for a 20X objective. Tried a few subjects that were at hand. In some cases the "effect" was minimal or nearly non-existent. But the blade edge of this single edged razor blade got very interesting and colorful.
Photographed at 50X using Olympus BHA, vertical illuminator, 20X objective with DIC, 2.5X NFK photo-eyepiece.
So the blue band is what, a few tens of microns across?
Next question of course is "What is it?"
At first look it resembles the oxide coating which builds up when ground steel gets hot, but I doubt that would be part of the manufacture. A surface treatment then, to provide a hardened edge? Blue - cobalt? Probably not, but perhaps it's written all over the packet!?
Sharp picture, of course :wink:
lauriek
Post by lauriek »
Cool shot! It's funny I was just reading up on knife sharpening and 'micro serrations' and then you post a picture of some! :)
Is this a brand new razor blade? I find the 'fibrous' look of the side of the blade interesting, I guess that's down to how these are ground...
This is a slightly used blade. To the eye it has a normal, bright, colorless steel look. The colors are "introduced" by the DIC lighting.
Here's a detailed explanation about what is going on:
http://www.microscopyu.com/articles/dic ... eddic.html
