Excitation is via an EXFO Excite-120 metal halide and a Rhodamine filter cube. The objective lens is a Planapo 63x/1.4 and the camera used is a Hamamatsu ORCA-AG.
The Apotome system is essentially a grid that is placed in the illumination path that reduces out of focus fluorescence - in other words, a combination of acquisition settings and an algorithm to make sense of the images allow for an optical section of a fluorescence sample to be acquired. The result is very similar to (and some may argue, better than) images acquired with a confocal laser scanning microscope; although, it is considerably less expensive.
The image below is a volume rendering of 72 images. If you click on the image, you will be brought to a movie of the pollen spinning around the (semi)-central axis; the movie is 17MB.
See here for more info on the Apotome system.
Definitely more to come!
