Both images: Olympus S Plan Apo 60/1.40. DIC with electronic flash. Canon 350D.
When I know I will be after cilia motion images, I always prepare the wet mount with "too much" water. This helps keep the cilia motion looking pretty "natural", but it means that there will be many subjects that are too "deep" under the cover slip to photograph, and for those close to the cover-slip DOF will be a problem. However, it also means that there is sufficient room for a subject to occasionally position itself so that I can get such a "head-on" shot.How do you manage to photograph the peristome more or less right from above?
