http://www.zoology.ubc.ca/courses/bio33 ... _cycle.htm
http://www.ciliate.org/conjugation.shtml
The third image is a single individual for reference.
The condenser I use has a rotating turret with circular openings that will take either a DIC prism or a phase contrast annulus. I cut a clear circular plastic disk to fit in one position, and then attached a round opaque paper circle to it's center. I tried several sizes until I had one that worked with the 4X and 10X. Since my 20X is a 0.70 NA and my 40X is a 0.95 NA I'll go to an oiled darkfield condenser if I want to use them. (I have an old Zeiss one that I have adapted to fit the Oly). For shots like the exposure is very critical. It is very easy to overexpose these if you are not careful.What sort of stop are you using for your darkfield Charles? Or are you using a dedicated condenser?
When I first saw these they were in one of my "large" sample bowls. I carefully put them on a slide but was wary of trying to place a cover slip over them. So I first took a few images with a 4X and the water just "pooled" on the slide with no cover (these shots). After I had a few I tried to add a cover slip, but even though I kept the slip "lifted" as soon as it contacted the water they separated.Did you study this for any length of time after the shot?
I think that is a part of the "problem". As wonderful as very high NA objectives are (generally they are Apos's and wonderfully color corrected as well), I find them difficult to use for darkfield unless the subject is extremely thin and positioned flat to the cover slip. Whenever I try darkfield with my 40/0.95 I think how nice it would be to have a 40/0.65 Plan Apo for this use. The best darkfield I have done with my 20/0.70 was when I rigged a makeshift "funnel stop" at the rear and photographed at a slightly reduced NA.I have high na objectives too which may not be helping
